Latest: ArtistKS
Overall: 17145
Online Now [63]:
Visitors: 62
Today: 20455
Total: 116008182
Forums › The Car › 206 Talk › Should they be okay
Should they be okay
Dan-
PostPosted: Mon Mar 12, 2012 1:38 pm Up
Hi, I've just purchased a set of Avo GTZ coilovers and going to fit them this weekend, now should i be looking to replace the top mounts, ARB bushes, and drop links while I'm doing to, i changed my drop links about 5 months ago?
Thanks Dan
PostPosted: Mon Mar 12, 2012 2:07 pm Up
check them while u do the replacing job,if they are in good shape,keep them,if not,replace them
PostPosted: Mon Mar 12, 2012 2:25 pm Up
Change your top mounts as it will save you a job later plus you already have the shock out
Dan-
PostPosted: Tue Mar 13, 2012 10:13 am Up
Ive spoken to euro car parts and they will do both top mounts for £45 Very Happy will be they good enough quallity? also will i only need to use the bearing or the rubber mounts aswell?
Dan
shell-vt
PostPosted: Tue Mar 13, 2012 10:23 am Up
Trade Rating: +46
YER IDE CHANGE THEM
york 16,3
Dan-
PostPosted: Tue Mar 13, 2012 2:41 pm Up
will get them friday, also if anybody knows the size of the nuts and bolts ill replace all of them reason i ask is i can get them all from work friday and would be very handy to know before hand
thanks Dan
PostPosted: Tue Mar 13, 2012 3:02 pm Up
Dan
Make sure they are both the same make and come with bearings
