Online Now [42]:
Visitors: 41
Today: 102455
Total: 117352314
Forums › The Car › 206 Problems › ECU, BSI, transponder ring for the ignition barel & chip
heyziq
PostPosted: Mon Jun 24, 2013 7:22 am Up
If i get a set of ECU, BSI, and Transpoder chip WITHOut the ignition barrel transpoder chip , will it work?
heyziq.com
PostPosted: Mon Jun 24, 2013 10:02 am Up
Without barrel aeriel, Yes.
heyziq
PostPosted: Mon Jun 24, 2013 12:40 pm Up
i try its working,but now the immo already lock..mine is preplex gti by the way
heyziq.com
PostPosted: Mon Jun 24, 2013 4:28 pm Up
What interface are you using?
Are you trying to code keys and using the 4-digit code?
heyziq
PostPosted: Mon Jun 24, 2013 9:48 pm Up
no did ot use any interface
i just swap the ecu over, using my old ring.. it works..on 1st start but then its getting immo lock Sad
heyziq.com
PostPosted: Tue Jun 25, 2013 1:40 am Up
How do you know it's immo locked though?
Checked the rellay unit under the ECU?
heyziq
PostPosted: Tue Jun 25, 2013 3:34 am Up
Had experience before..plus i swap another ecu+bsi and it working well again. s**t need do key learning back ?
heyziq.com
PostPosted: Tue Jun 25, 2013 3:57 am Up
OK, write a long detailed description of what the situation and history of your problem you are trying to solve now, and maybe people can help in a better way.
I can't see how you can tell the immo is locked unless you are getting MFD message or something, without putting it on Peugeot Planet..
