Latest: cogeim7
Overall: 17185
Online Now [781]:
Visitors: 780
Today: 44813
Total: 147357296
Forums › The Car › 206 Problems › poorly gti 180
poorly gti 180
gaznandrea
PostPosted: Thu Dec 04, 2014 2:28 am Up
My car has been diagnosed with a intermittent misfire at idle changed spark plugs and coil pack but still the same has abybody got any ideas as to what is problem cheers
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
mattymj
PostPosted: Thu Dec 04, 2014 5:51 am Up
Come to Norfolk. I can plug it into my pp2000
gaznandrea
PostPosted: Thu Dec 04, 2014 9:51 am Up
What will that tell me
gaznandrea
PostPosted: Thu Dec 04, 2014 9:53 am Up
Been put on diagnostic machine at peugeot garage cant tell me what wrong
PostPosted: Thu Dec 04, 2014 1:33 pm Up
Could be a dodgy hydraulic lifter. Bit of a job to fix it because the cams and cam housing need to come off. At least you know what cylinder it is. So you just need to change four. Has it had an oil change recently?
PostPosted: Thu Dec 04, 2014 1:38 pm Up
They did tell you which cylinder it was didn't they?
gaznandrea
PostPosted: Thu Dec 04, 2014 2:38 pm Up
No they didnt
gaznandrea
PostPosted: Thu Dec 04, 2014 3:14 pm Up
No its not had oil change in last year
PostPosted: Thu Dec 04, 2014 3:48 pm Up
That wont help the lifters stay healthy - unless it's only done a low mileage.
gaznandrea
PostPosted: Thu Dec 04, 2014 5:52 pm Up
Do you think that might cure it
PostPosted: Fri Dec 05, 2014 3:36 am Up
give it an engine oil flush,with a new oil and oil filter,and see how things goes,if not,then you have to get it checked again to see which cylinder have misfire,and then do what Edward said,which is working on the lifting valve.
PostPosted: Fri Dec 05, 2014 6:47 am Up
Dodgy injector?
PostPosted: Fri Dec 05, 2014 6:58 am Up
They will know which cylinder has the problem and to not tell you when you've paid them isn't fair of them. Could also be dodgy injector wiring...
Carlos_WR1
PostPosted: Fri Dec 05, 2014 8:57 am Up
My 138 had an intermittent misfire on cylinder 2 and it turned out to be an injector. i replaced the injector myself (not a big job) and its running like a dream now.
I managed to pick up a new injector for £36 incl postage.
Project2062014
PostPosted: Fri Dec 05, 2014 10:04 am Up
Mine advances timing on idle & jolts the car . This normal ?
Not had it with open throttle .
