Online Now [24]:
Visitors: 23
Today: 4738
Total: 116656640
Forums › The Car › 206 Problems › REV counter
REV counter
wolfie-uk
PostPosted: Fri May 27, 2011 6:42 am Up
OK, so now having sorted out the minor problem of no reverse, and having serviced inc new cam belt, we have the other minor niggles to sort.
The rev counter just "flicks" around 0 RPM, is it a electronic module or cable driven system, is it an easy fix ? any advice etc most welcome.
Dad - daughters mechanic
PostPosted: Fri May 27, 2011 7:27 am Up
The rpm are taken from from the crank position sensor, so electronic.
However the engine wouldn't run if it doesn't work properly.
So maybe an instrument cluster problem.
