Online Now [197]:
Visitors: 196
Today: 48543
Total: 138905053
Forums › The Car › 206 Problems › Central Locking Problem
jpvd
PostPosted: Mon Jun 20, 2011 8:12 am Up
my key does'not have a button (no remote central locking) so just wondered how its possible with mine?...cheers
always something to fix...
PostPosted: Mon Jun 20, 2011 8:31 am Up
You'd need install remote central locking. You can't just buy the fob and it work.
On a side note, what does central locking have to do with this thread? :/
jpvd
PostPosted: Mon Jun 20, 2011 8:36 am Up
hi Lee...thanks for the reply
we just purchased a 206 1.4 and have the immobiliser fault, getting very annoying. Will start after a few attempts.
I want to reset the BSI unit and see if it solves the problem. If not i'll get the mechanic to plug his pc in and take it from there.
Just in your description above it states that after resetting you have to hold the key fob button down in the barrel for 10 secs. We obviously don't have a button, since it snot remote central locking.
any advise?...
thanks in advance
PostPosted: Mon Jun 20, 2011 8:43 am Up
That would be only to resync the remote central locking if you have it, which you don't so it should be fine.
Sounds like the ring on the ignition barrel has gone. Not expensive to replace.
jpvd
PostPosted: Mon Jun 20, 2011 11:41 am Up
Thanks lee, thats what i've been thinking. Found this one on ebay > cgi.ebay.co.uk/ws/eBay...97.c0.m619
Should this do the trick?...
thanks again
paul
jpvd
PostPosted: Mon Jun 20, 2011 11:44 am Up
or am i best just going to the Peugeot dealer and getting them to look it up on the system....thinking they should have them in stock or be able to source one quickly enough....?
PostPosted: Mon Jun 20, 2011 11:59 am Up
They are only £7.86 from Peugeot. Part number 6160 76
PostPosted: Mon Jun 20, 2011 12:07 pm Up
Cheap as chips Cool
Wonder why the non plexed transponder aerial is 3 times the price Laughing
jpvd
PostPosted: Tue Jun 21, 2011 3:57 am Up
thanks again Lee...just rung main dealer and mines the other one (is it non-plexed?) so its £22....if it sorts it then its money well spent, will get the part on thrusday and let you know if its done the trick....
thanks again!
PostPosted: Tue Jun 21, 2011 5:12 am Up
Sorry took it forgranted yours was multiplexed with you originally posting in the Multiplexing and BSI thread
jpvd
PostPosted: Tue Jun 21, 2011 8:48 am Up
my bad...i don't know the difference, i'm guessing its to do with what key you have. Even the main dealer didn't know the difference...lol
PostPosted: Tue Jun 21, 2011 8:49 am Up
Its the whole electrical system in the car Laughing
Multiplexing is a lot more complex
