Online Now [263]:
Visitors: 262
Today: 88481
Total: 143397371
Forums › The Car › 206 Problems › Loss of Electric power
angela1
PostPosted: Tue Aug 30, 2011 4:15 am Up
Hi all, please help, I have owned my 206 Auto for about 3 months and al has been well.
Until now.
Went to drive it to work the other day, starts fine, sounds fine, but when I started driving all the electrics in the car went dead, but the car was still running, they go off for about 2seconds then come back on.
Please help Sad
Angela
PostPosted: Tue Aug 30, 2011 4:16 am Up
What year is your 206?
angela1
PostPosted: Tue Aug 30, 2011 4:18 am Up
Y-reg, 2000 I think
Angela
PostPosted: Tue Aug 30, 2011 4:23 am Up
Check the battery connections are both clean & tight.
On the battery MINUS - lead follow it down to where its bolted on to the top of the gearbox & check the cable here at the big terminal, on early 206's like this they are well known for breaking here, they can look perfectly fine but if pulled gently the cable will come out of the terminal.
That cable should then loop of from the gearbox & be bolted to the inner wing.
When you say all the electrics go off do you mean everything? headlights, radio, instrument cluster etc.
angela1
PostPosted: Tue Aug 30, 2011 4:26 am Up
I mean everything, lights, stereo, instrument panel the whole lot.
Very confusing as the car still runs Confused
Angela
angela1
PostPosted: Tue Aug 30, 2011 4:37 am Up
All cables and wiring ok, not loose at all ?????
Angela
PostPosted: Tue Aug 30, 2011 11:51 am Up
Check negative earth strap to gearbox
