Latest: tebas93089
Overall: 17179
Online Now [117]:
Visitors: 116
Today: 38217
Total: 138185070
Forums › The Car › 206 Problems › Engine light on - code p0711 - Transmission Fluid Temp
chemaz101
PostPosted: Tue Oct 04, 2011 3:13 pm Up
Hi
Engine light came on the other week and the code iv got from it is P0711 Transmission Fluid Temperature Sensor A Circuit Range/Performance
But not sure what could cause that, is there anything i can check/easily do to sort it or do you think im going to have to take it to the garage?
Cheers
206
PostPosted: Tue Oct 04, 2011 3:24 pm Up
you got an auto 206?
chemaz101
PostPosted: Tue Oct 04, 2011 3:45 pm Up
sorry my bad shoulda said what model the car was Razz
its a manual y plate 1.1l 206
206
PostPosted: Tue Oct 04, 2011 3:51 pm Up
What diag tool are you using?
Sounds like it's incompatible
chemaz101
PostPosted: Tue Oct 04, 2011 3:58 pm Up
An ELM327 usb with proscan 5.9, was just some cheap thing i got from ebay
206
PostPosted: Tue Oct 04, 2011 4:08 pm Up
Probably not reading the protocols right then or a dodgy connection
AX-Rated
PostPosted: Wed Oct 05, 2011 1:03 pm Up
Try using scantool with the ELMs, i've found it performs much better and covers just about every car ive thrown it at against other programs 'provided'
Black 03 GTi
PostPosted: Wed Oct 05, 2011 2:07 pm Up
I use the Palmer Performance Engineering software with the ELM lead. Never had any problems.
Did you get a disc with proscan on or was it one of the download links that ebay seller like to send out?
It is possible that the software is set up for one of the other protocols. Try checking your settings to make sure it is set to ISO and not PWM, CAN or VPW
