Online Now [292]:
Visitors: 292
Today: 74177
Total: 142695506
Forums › The Car › Solved 206 Problems › Track rod end? Been to garage update 05-02-13
Go to page Previous  1, 2
Tolkienfan001
PostPosted: Tue Feb 05, 2013 11:53 am Up
Trade Rating: +13
So I have just been to the garage and they have confirmed there is play in the track rod end. They also said there is slight play in the lower arm back bush.
I am going to order two track rod ends and replace both. They have not been done before. So I thought best to replace both.
I am unsure what to do with the lower arm back bush. Can I replace just the bush or is it the whole arm?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Tue Feb 05, 2013 1:58 pm Up
Replace the lower arm. If you don't you will get tyre wear and that will soon get to cost of replacing lower arm.
I have used the registration mark from my daughters 1.4 8V car and think the cheapest reasonable quality you will get is from buypartsbuy as follows:-
www.buypartsby.co.uk/b...trol-arms/
These are QH parts and that is a long (1947) established UK company.
Tolkienfan001
PostPosted: Tue Feb 05, 2013 2:06 pm Up
Trade Rating: +13
Thanks for that.
If I put my car in it gives me a price of £30 / arm.
I have rang my local auto parts place. They can do two track rod ends and two lower arms for £78 inc vat.
At that price am going to get all parts on Thursday and change them this weekend. Job done then.
2005 1.4 16v Sport
PostPosted: Tue Feb 05, 2013 2:30 pm Up
Get four wheel alignment done when the parts are fitted.
Do not bother with two wheel.
The four wheel will take into account where your rear wheels are pointing (they won't be where Peugeot intended - they never are) and make adjustment at the front for that.
Even though you are on a far more accurate machine you should only pay for adjustments nmade so the price will be the same as tracking £35(ish.)
Tolkienfan001
PostPosted: Tue Feb 05, 2013 3:53 pm Up
Trade Rating: +13
Will do thanks
2005 1.4 16v Sport
usher
PostPosted: Tue Feb 05, 2013 4:16 pm Up
for alignment i recomend kwik fit they have a good bit of kit in there
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Tue Feb 05, 2013 5:04 pm Up
Depends which Kwik Fit but I haven't seen one yet with good kit but I always avoid Twit Fit. Maybe they have improved to try to catch up with others. Even if it is good kit a poor operator can still mess it all up. The best kit is made by Beissbarth with Hunter not far behind; as what kit they have.
When they (who ever that is) does the alignment watch to see if they check all suspension components for wear before doing the alignment.
A good operator will check the suspension first and if there is wear advise you of that and recommend to you that it is not aligned until it is repaired. Very few do that; it may be management pressure to generate income or it might be poor training.
Tolkienfan001
PostPosted: Wed Feb 06, 2013 2:29 am Up
Trade Rating: +13
I would not trust kwik fit to change a bulb!
When I put my nimrods on the car they came with 4 used tyres. Between 20mph and 40mph I was getting a horrible noise from the front left.
I stopped by kwik fit for them to put it on the ramp and check nothing was rubbing. All they found wrong was I needed new discs and pads. (I already knew this and this was not what I asked them to do.)
They then told me the new alloys needed different bolts and the noise was one bolt going to far in and rubbing on the disc!! This did not even make sense!
I took the car home checked the wheel myself and found the tyre to be unevenly worn. Swapped it to the back noise gone!
Never again will I go to TWIT FIT as KandL puts it!
2005 1.4 16v Sport
rick-gti
PostPosted: Wed Feb 06, 2013 3:19 am Up
I have a pair of track rod ends that i got for a gti if there any good to you mate.
clio 197sport owner
Tolkienfan001
PostPosted: Wed Feb 06, 2013 4:06 am Up
Trade Rating: +13
Thanks for the offer. Just bought two for £15.00 BNIB.
2005 1.4 16v Sport
PostPosted: Wed Feb 06, 2013 2:28 pm Up
If you had an Alfa 147 or 156 you would let Twit Fit fit the headlight bulbs. Double jointed and sliced hands is the only way to do it.
Second thought = no. They wouldn't seat them properly and I would have rubbish beam pattern.
Page 2 of 2
