Latest: tebas93089
Overall: 17179
Online Now [176]:
Visitors: 175
Today: 4821
Total: 138370874
Forums › The Car › 206 Problems › 206GTi "rumble" when changing gear
p4ul
PostPosted: Fri Jun 28, 2013 7:05 am Up
Hi there guys,
Basically, pulling off in first, moving into second and occasionally even third produces a rumble under the car. I can't locate it, but I have been advised by a colleague at work that it could be a clutch plate problem? Also, someone suggested that a mount somewhere could be loose?
I realize there are other similar problems on here, but no one has specifically addressed the problem as a rumble so I think thats where I differ.
Any help or advice is welcome, I can also post a video if my phone can pick up the noise.
Cheers, Paul
Big_Rich180
PostPosted: Fri Jun 28, 2013 7:27 am Up
Clutch release bearing?
magistar
PostPosted: Fri Jun 28, 2013 8:11 am Up
Clutch judder? Does it only happen when you're releasing the clutch pedal or while you're changing gears
