Latest: Worthy967
Overall: 17143
Online Now [307]:
Visitors: 306
Today: 103581
Total: 115293815
Forums › The Car › 206 Problems › 206 intermittently cutting out
Peugeotowenr
PostPosted: Fri Apr 24, 2015 6:27 am Up
Wondering if anyone can help, first time poster. My 206 keeps intermittently cutting out and displaying the engine warning lights and sometimes is unable to start again after cutting out. Sometimes after cutting out it displays fault codes and others it says no communication from the ecu.
I've had coil pack replaced, new crank shaft sensor and the latest garage re earthed all the wires in the fuse box, which seemed to rectify the problem, but yesterday it went again. An auto electrician said I need a new ecu.
I've noticed a few people have had some problems with cutting out and misfiring but not seen anything which says they have sorted the problem and is fine. It's only got 80000 on the clock was hoping to get another 30/40k out of it before trading it in. Any help massively appreciated.
PostPosted: Fri Apr 24, 2015 8:16 am Up
1.1, 1.4, 1.6, 2.0?
What are the fault codes?
Peugeotowenr
PostPosted: Fri Apr 24, 2015 12:10 pm Up
It's a 1.4. Can't remember the codes there have been three or four occasions they have been found. From memory one was cylinder and coil issues.
ukskater01
PostPosted: Sat Apr 25, 2015 8:02 pm Up
Is the gearbox earth ok? Also did they replace the spark plugs when the replaced the coil pack?
Peugeotowenr
PostPosted: Tue Apr 28, 2015 8:12 am Up
Gearbox earth is fine I think. Yeah replaced coils and spark plugs.
Peugeotowenr
PostPosted: Tue Apr 28, 2015 8:25 am Up
oldskoolz
PostPosted: Tue Apr 28, 2015 8:35 am Up
Double check your earth, sometimes it looks ok on 1st look but if you look deeper it is actually frayed inside.
Sounds like it could be your ICV aswell. Whip it out and give it a clean with some carb/brake cleaner.
Black 206 Gti. Soon to be 2.2
waine_b
PostPosted: Mon May 04, 2015 10:25 am Up
Did you get this sorted ? I have the same problem with mine, can drive 100km's one day no problem and then do less than than a km the next day and it will cut out.
It used to do it more after I had been in slow moving traffic, so changed the Crank sensor and coil Pack, seemed ok for a while the reappeared. Now it's getting more frequent but no error codes when on diagnostic.
Really becoming a pain in the a**e as can't trust the car anymore and wary of driving it in heavy traffic just in case it conks out.
Has anyone actually ever gotten to the bottom of this as it seems to have been going on for years judging by the threads on the subject.
Shadowstalke
PostPosted: Tue May 05, 2015 11:13 am Up
For the record, and anyone reading this later. If you have a Diesel, check your EGR valve isn't sticking or gunked up
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
