Posted: Tue Sep 01, 2015 6:36 am |
I changed the drivers side shock on my 206 took the car for a test drive and the was a knocking noise . l now cannot get the car to jack up on both sides thanks for any help
Posted: Tue Sep 01, 2015 6:40 am |
Im so confused by this, how can you not jack up both sides?! Pictures are required
| Team Impossible Possible
Posted: Tue Sep 01, 2015 7:52 am |
What jack are you using?
Where are you attempting to lift the car from?
Where did you place the axle stand to support the car while carrying out the suspension work?
Posted: Tue Sep 01, 2015 9:16 am |
Addaz wrote: |
Im so confused by this, how can you not jack up both sides?! Pictures are required |
I have a picture in my head of the suspension having fallen apart and one side of the car sat on the deck preventing the jack from going under.
Posted: Tue Sep 01, 2015 3:49 pm |
you have messed that up then.
Posted: Wed Sep 02, 2015 5:13 am |
I bet the knocking noise is the drop links.
