Latest: tebas93089
Overall: 17179
Online Now [88]:
Visitors: 88
Today: 52563
Total: 138246104
Forums › The Car › 206 Problems › 1.4 HDi - Latest Issue...
Orta
PostPosted: Tue Nov 17, 2015 7:00 am Up
Ok, possible dodgey Head Gasket aside which I haven't had a chance to look into yet. The next issue to rear it's head is I've got a very laboured sounding belt (assuming it's cambelt).
It's odd because the cambelt was new circa 12k ago/8 months ago.
It sounds fine when you first start her up, but then after moving a little it's very loud on tickover. So loud in fact it drowns out all other engine noises.
I've tried some wd40 on the various cogs as this solved a similar problem on my dad's fiesta (same engine) but this doesn't seem to have solved the problem. I've attached some videos that hopefully let you hear the noise.
I know it's difficult without taking a look but does anyone know what the crack with this is?
youtu.be/OrJifc_CKP8
youtu.be/0jcKL7Kg5Bk
youtu.be/JMMbeq-1_JQ
2006 206 1.4 HDi SW Verve
gazza82
PostPosted: Tue Nov 17, 2015 1:02 pm Up
It's not the bottom pulley starting to fail is it? I had a noise that got louder as the engine warmed up and the pulley was slowly destroying itself!
I haven't looked at or listened to the videos BTW .. so guessing.
PostPosted: Tue Nov 17, 2015 5:27 pm Up
Probably bottom pulley on the cambelt, which runs the aux belt.
Danpemble
PostPosted: Wed Nov 18, 2015 1:24 pm Up
I had my bottom pulley go. youtu.be/HEZu2fcBgm4 a little video I took, as you said this was louder then all other engine parts.
