Posted: Sat Feb 13, 2016 6:46 am |
OK my car has just failed its MOT on rear suspension - apparently I need a new rear axle and I've been quoted MOT for 2nd hand part and fitting - does this sound about right?
Posted: Sat Feb 13, 2016 6:59 am |
offside rear Torque/reaction arm has excessive play in a pin/bush (2.4.G.2)
Posted: Sat Feb 13, 2016 7:14 am |
sounds fine.... there are alternatives with repair kits available
Posted: Sat Feb 13, 2016 7:34 am |
is it not the whole rear axle which need replacing then? Just an arm? Literally stuck for what to do! I haven't a clue about these things!
Posted: Sat Feb 13, 2016 8:54 am |
could get a refurb fited with brand new bearings and stub pins etc. around £200 if i remember www.axledirect.com
Posted: Sat Feb 13, 2016 9:19 am |
I imagine plenty of used axles are past their best now. Safest bet is a refurbished axle.
Posted: Sat Feb 13, 2016 11:59 am |
Thanks guys
Posted: Sat Feb 13, 2016 3:43 pm |
i just replaced the whole lot was best option, imaxle did mine
