Online Now [390]:
Visitors: 389
Today: 82332
Total: 142592745
Forums › The Car › 206 Problems › 1.4hdi speedo
1.4hdi speedo
Duckworth87
PostPosted: Wed Sep 02, 2020 5:20 pm Up
Has anyone had issues with or know of any known faults with the Speedo on a 1.4hdi?
Mine can drop out at any time, sometimes it comes back and sometimes stays not working and then the airbag light comes on the dash and will not work again until the car has been turned off for 10 mins at least.... It's a non abs model so can't be a wheel speed sensor. Not sure if the Speedo drive is the one on top of the gearbox but can't seem to find a replacement anywhere?
Any help greatly appreciated!
PostPosted: Thu Sep 03, 2020 6:30 am Up
Need to know if its a non plexed OR multiplexed 206.
By the description of the fault id say non plexed but you need to check.
Duckworth87
PostPosted: Thu Sep 03, 2020 7:15 am Up
How do I find out if it's non plexed or multiplexed? I don't even know what that is?
gazza82
PostPosted: Thu Sep 03, 2020 1:48 pm Up
How old is the car? 02 plate?
Also is the radio remote a long stalk or a wider flatter "paddle" shape? Does the radio, assuming it is standard, have a screen built in or is that in the MFD and the radio shape is rectangular? I think the key fobs are also rounder on Non-plexed.
Duckworth87
PostPosted: Thu Sep 03, 2020 7:13 pm Up
It's a 2003 '53 plate, stalk is the "paddle" type. Original radio was just buttons and the radio data came up on the little screen on the top of the dash.
gazza82
PostPosted: Thu Sep 03, 2020 9:02 pm Up
Multiplexed then. 100%
Duckworth87
PostPosted: Fri Sep 04, 2020 7:44 am Up
What is non plexed/multiplexed?
2003 1.4 hdi daily runabout s**t box
gazza82
PostPosted: Sat Sep 05, 2020 4:23 pm Up
the way the electrics work .. multiplex is an early canbus system I believe. Parts are NOT exchangable between the two systems.
Google it.
Sim
PostPosted: Mon Sep 07, 2020 8:58 pm Up
Speedo sensor is at the back of the gearbox, GSF stock 'em: www.gsfcarparts.com/929pc0400 worth checking with dealer for probably a similar price of the OEM part.
Here's where: www.youtube.com/watch?v=oppyVWM8OMU
My ABS-less 1.4 HDi had been temperamental with its speedo showing nothing, but came back to life once I drove above 60 MPH, and not had problems since.
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
