Posted: Sat Feb 28, 2015 3:38 am |
Andrew wrote: |
Awesome as ways
How did you route the reverse camera through the boot? |
What do you mean mate? The camera is were the 3rd brake light is and i ran the leads through the seething were all the other wiring goes
| Team Impossible Possible
Posted: Mon Apr 20, 2015 7:26 am |
The 1.6 engine lives!
If anyone has me on facebook you can see the video there (adam chafer if you havent)
Posted: Mon Apr 20, 2015 10:34 am |
Seen it Mate. Looks good
Posted: Mon May 18, 2015 6:32 am |
Well this year is now out of the question...
Posted: Mon May 18, 2015 7:21 am |
| Black 206 Gti. Soon to be 2.2 | |
Posted: Mon May 18, 2015 7:52 am |
Not to sure what caused the fire but she went up in a big way
Posted: Mon May 18, 2015 8:14 am |
Addaz wrote: |
Not to sure what caused the fire but she went up in a big way |
man that sucks! don't let it get you down though, hopefully was just something small that was overlooked. either way I know she'll be back and stronger than ever
Posted: Mon May 18, 2015 8:56 am |
Posted: Mon May 18, 2015 2:59 pm |
Very unlucky
Goodluck with the repairs!
Posted: Fri May 22, 2015 5:21 pm |
Fwark! That not good mate. Hope its not too bad.
| Iv had:
Now : GTi 180 again - Build thread | |
Posted: Sat May 23, 2015 2:31 am |
Wow. That's not good but hopefully the expensive bits are salvageable. I've got an extinguisher in mine and I'm thinking of buying another too.
Posted: Sat May 23, 2015 4:25 am |
Edward wrote: |
Wow. That's not good but hopefully the expensive bits are salvageable. I've got an extinguisher in mine and I'm thinking of buying another too. |
I had one 1kg powder one, i highly advise two 2kg ones! And not powder! As it put it out but it just started up again!
Posted: Wed Jan 06, 2016 5:41 pm |
I should really update this since its been half a year
Well what can i say?
Have i done loads?
No not in my eyes
What have i been doing?
Redoing everything I started fixing the bits that need attention and then ended up redoing most of it, one weekend at a time. Its getting close but its painfully slow process!
Whats left?
Fuel system, moving to PTFE aeroquip, building the mil spec loom (when i have the dam tools!), finishing of the relay board and then paint work again!
Is she changing?
Yes, very much so. She will be the first 206 to be done this way, and i hope to break the internet a touch when shes done!
Posted: Tue Jan 19, 2016 10:26 am |
Now it's clear why photos from you are also classified, for now
Posted: Sun Apr 03, 2016 2:55 pm |
Also after speaking to a good engine building friend of mine, I just wanted to advise people on whoever are deciding to turbo-charge their 206 (TU specifically) that the plastic fuel rail is a danger waiting to happen!
Apparently my EGT probe was not working as it should have, so my thoughts of 500 or so degrees in the downpipe should have been closer to more 800 to 900 after a few high speed runs. The exhaust on the TU runs underneath the engine, and as we know heat rises, so hence why the fuel rail lifted in the centre and allowed the injectors to leak everywhere
Becareful fellow turbo TU owners!
